1 - 8 of 8 Posts
Going to build a build a custom underseat Crew cab box for this sub:
10" JL Audio 10w0v3-4. 300 watt rms. Going to power it with my Hifonics 320 wrms amp.
10WØv3-4 - Car Audio - Subwoofer Drivers - WØv3 - JL Audio
JL recommends a 1.125 ft^3 ported box and 0.65 ft^3 sealed box.
Ok so do yall think i can get good results with a ported box like this one: ...
...or should i just do a sealed box at their recommended 0.65 ft^3?
I would plan to build it downfiring of course thpugh. Slot Port in the same spot
Does anyone else have this sub or reviews on JL subs?
Input appreciated,
Thanks
Kurt
Sealed usually gives you a cleaner bass and ported gives you louder bass. Ported is generally good for if you have a trunk, which kind of makes it sealed. A sealed box would do better for our frontiers since we don't have a trunk to put the sub in. Also the cab is so small that you will get more than enough bass to never have to use anything close to max output, unless your having a block party and your the entertainment lol.
Some more background information on this subject
http://www.crutchfield.com/S-rKCw44IXZPl/learn/sealed-or-ported-subwoofer-enclosures.htm
Also go with the JL sub, you can't go wrong with them if money isn't an issue. Here was my setup
http://www.jlaudio.com/10w1v3-4-car-audio-w1v3-subwoofer-drivers-92081
http://www.jlaudio.com/xd600-1v2-car-audio-xdv2-amplifiers-98604
Pickup truck cabs are not physically long enough for real low wavelengths to be heard. Not sure a Suburban is even long enough.
I'm a sealed guy cuz I like tight, punchy bass.
Go to DIYMobileaudio for more opinions than you can shake a stick at. Careful, you can get lost in there.
Awesome, thanks guys.
Engesetb how many cubes was your box?
Shift_rush, yeah im tired of looking at hundreds of sub reviews anyways lol.
Street_sweeper, not trying to go all out on this one. Gotta have my bed space
Sent from my SM-G930V using Tapatalk
Rogue Admin
2007 LE 4x4 Crew Cab Long Box
I was always a ported guy, even in a small S10 I had. Used to run (2) 12" JL Comps at one time, with the ports right between the seats; it would make you shirt blow in the wind. I blew up a lot of sealed box subs, they never had enough punch for me at that time.
1 - 8 of 8 Posts
