I'm in the process of searching, but if someone can point me to a solution...
It's single digits & windy. Truck won't start, just clicks (as if the battery were dead) Measure the batt volts and its 12.3 and even threw the charger on for S&G and it was flowing .3A (indicating good charge)
Scan tool reads 12V so ECM also sees a full charge. batt cables are tight, starter cable is tight,
I've tossed a heater in the engine bay along with a blanket to help keep the heat in thinking/hoping its something in the ECM or a block sensor that isn't liking the cold.
It ran fine 2 days ago.
thanks in advance.
(and no, I can't just push it into the garage to warm it up sadly)
thanks in advance.
