I had these on my Frontier for a few years. I feel like their construction, much like the oem leafs, 'leaves' much to be desired. Their design, regular leafs and overload leafs has its drawbacks. In their early life I felt I needed to add weight so they wouldn't beat me up each drive. Loading the truck up gave the smoother ride I was looking for, at the expense of gas and wear and tear on the truck. After a while I was riding on the overloads all the time. It didn't matter how loaded or unloaded I was. I had a backache after any longer drive. Greg at PRG suggested I remove the overloads and add air bags to act in their place. This improved the ride, and I had the ability to adjust the air bags to match the load I was carrying. Unfortunately without the support of the overloads, I ended up developing a crack in the second from the top leaf on the passenger side.
I ended up ordering Alcan's to take their place. After weighing my truck at a CAT scales and passing on this info to Bill at Alcan, he said they were the correct weight, just not the best design. Bill made me a pair of 8 leaf progressive leafs. +600 pounds at 2" of lift. I also kept the air bags in, for when I'm towing also, or I have my slide in camper in the bed.
That being said, I have an Xterra also. I bought it earlier this year it has the stock leaf packs with the PRG 2 leaf add-a-leaf and the overloads removed. It is leaps and bounds better than the stock setup.
If I was you I would consider trying an add-a-leaf or a progressive leaf pack, like Deaver's or Alcan's. I'm not sure what you're trying to accomplish, or your budget. Both should weigh on your decision.
I hope this is comprehensive enough. Please, if you have any other questions just ask. The link in my signature may have more helpful info. Unfortunately The photos are missing because of Photobucket.
