1 - 2 of 2 Posts
so I know I can put the titan susp on my frontier so if that's the case if I wanted to go bigger cant I just put a titan lift on my frontier I know I will have to change some parts but if it bolts up it bolts up or maybe im justbad when it comes to building lifts
2012 Nissan Frontier
The short answer is not really, but it depends on the lift you are looking at. The bolt pattern for the top hat on the Titan is different. The Titan rear suspension has little differences too.
The long answer is you can make some things work, depending on how many things you're willing to swap out and modify.
1 - 2 of 2 Posts
