1 - 3 of 3 Posts
31s are very small (265-70-16)- this is the stock SE/SV size
32s are still small on a t swap (265-75-16)- this is stock Pro4X size
-Other oddball sizes: 275-70-16, 265-70-17
33s fit well with little to no trimming, no fiberglass needed (285-75-16)- most common bigger size used, no regear required
-Other oddball sizes: 305-70-16, 285-70-17
34s will need a good amount of trimming with no glass (295-75-16)- regear should be considered
35s will need significant trimming without glass (315-75-16)- regear strongly recommended
NOTE: All of the above assumes stock wheel offset/backspacing
1 - 3 of 3 Posts
