Does anyone have any info about what is needed or the best way to go about it?
I'm in an interesting situation where I need to rebuild the back end of an 07 KC SE-V6 Auto 4x2 (my dads truck that was rear ended and "totaled" that we're making a work truck). He said if I can take the parts from my truck and put them on the 07 and upgrade mine, it works out even better...
Soooo, I've already found a few 08+ axles, but I hear there are no good limited slip options for them. I guess my questions are, what type of work is it to get one going and is it a better option to just find a junkyard replacement for the stock axle and upgrade my D44h?
I've done all of the work on my truck so far, and I can weld, so those aren't limiting factors. And I was planning on doing the rear end soon (see this post: http://www.clubfrontier.org/forums/f26/what-will-happen-60831/) , so this just speeds up the process...
Any info is helpful, so throw your ideas at me.
Thanks
P.S. here is a pic of the 07. suprisingly, little frame damage, and we're going with a flat bed. Plus I have the whole front suspension off of my truck...
Thanks
