1 - 20 of 58 Posts
k i have the titan axle with 2.96 gears.. off an 04 and will come with drilled and slotted rotors, titan calipers with "green stuff" pads-450obo
titan leaf springs and bushings-100obo
extended shackles(will drop the rear end like crazy!)-50obo
I need this stuff gone asap!!!!!! will take offers....
oh have titan front diff/ housing and front drive shaft has 2.96 gears also-350obo
daily.... bump.... will work with offers!!! and can ship as long as you cover it...
bump for springs!!! come with u bolts bushings and rear extended shackles... 50 bucks!!!
would it work if i wanted to swap in my factory locker and the 3.36?
pretty sure it'll drop right in (from what i've heard) ask terrible, hes seen the insides of a few different diffs. You might need to figure out how to wire the locker but its been done before.
I'd doubt an eLocker will fit in an non-locked housing. The r/p will swap but the extra crap for the locker will be missing. You may be able to get it to work but it won't be simple unless you just write someone a check for the work.
Discussion Starter · #17 ·
curious on why your taking everything off??? You have a clean a$$ truck.. only if i could afford a titan..
How much are you trying to get rid of your front c/o and bypasses? are they 10"?
thanks, and I am getting rid of everything to get a new axle made by gmr and a race kit that im going to have made and be 2wd to have deeper rear gears than that are made for the t. Eventually im going to do a cab cage and race this truck :)
and yeah the coilovers i have are 10" but i sold the bypasses already and im selling the c/o's for 1,000 obo and they are basicaly new, have less than 400 miles on them and comes with dual rate hardware and a main 600lbx16" and top 500lbx4.5".....
and as for the rear axle i can hold it for you if you can put a deposit down.... I really need the cash to get my axle started and to get enough down at the fab shop that is going to do my new race kit/ shock hoops/ brace....
LTtitan hit you up about it on DR.. damn, within the next 4 months i will be having about 7G's comming my way.. F*** I wish i was back in Cali so i can do things right the first time instead of trying to piece things together hear and there.
Cant wait to see your new set-up.
Discussion Starter · #19 ·
well i could ship the Lt kit :)
and if he doesn't get the axle i can hold it for you if you want to put a down...
you wont find a better deal on either the lt kit or the axle with the rotors and calipers etc.
let me know..
1 - 20 of 58 Posts
