Anyone out there happen to have just he outer cv off of a Titan axle shaft laying around?
I'm assuming for the front or the rear? I can get both axle shafts off a 09 titan if u want to just pull the axle out and replace?
Sent from my SCH-R970X using Tapatalk
Out of the front. I really just want the outer cv joint I don't want the shaft or anything like that
Can I ask why? I mean new CV's aren't super expensive if you're trying to save money.
I have custom extended axle shafts to be used with a mid travel kit, aftermarket cv shafts have a different spline count than an oem shaft. I have three of the four cvs installed the last one was screwed up. I've been through three "remanned" shafts with no luck. The spline count was off
Top is oem bottom is aftermarket. They have different splines
