So after much reading, I still have some axle questions before I buy a Titan PRG suspension swap.
Because now would be a good time to do a Titan front dif swap also, if it would work, and be an improvement.
#1. Are the spider gears in the Titan M205 auto, with big tow / offroad package, 3.357 gears front differential,
stronger and larger, than the frontier m180 front differential spider, and side gears?
I don't see any point in swapping if the gears are not any sronger.
Other than the housing, and half shafts being stronger in the m205, the gears would still break.
#2. Is it ok to run the Titan front differential with the 3.36 gears, with the 3.357 gears in the rear axle?
Or is this enough of a difference to cause problems?
#3. Can the 5A C200 rear differential, with 3.357 gears, in a 2008 frontier, SE, 4X4, crew cab, automatic, be run with the Titan M205 front differential with 3.36 gears?
#4. What gears are in the M180 front differential, in an 08, 4x4, SE, crew cab, automatic?
Wouldn't they have to be the 3.36, or 3.357 gears to match the rear, if they are the 5A C200 3.357 axle gears?
#5. Would the cruise control system stop working if I do a Titan front differential swap on this model of frontier?
