1 - 3 of 3 Posts
i searched and didn't find much so ill just ask,Will the stock nismo tire size 265/75/16 in an all terrain tire rub if i where to put it on a 16x8 pro comp wheel at stock height? Any input would be great. Thanks
You would have to trim the fenders. There are other wheels out there.
This is a simple thing for you to figure out. Take the backspacing and offset of the oem nismo rim and the one you want. Then go and measure the difference between you current wheel and the frame/fender/etc... As long as your current distance is more then the difference between you nismos and aftermarket rims, you should be good.
1 - 3 of 3 Posts
