1 - 3 of 3 Posts
I have a tire question that you may be able to answer. I have a 2013 Crew Cab SV 2wd...when I do this I plan to do a spindle lift 6" in the front and 4 inches in the rear.
With the rim I am open to 16's through 18's. I prefer for them to stick out so from what I understand I would want a negative offset right.
16's I like to either go with 305 to 315's....the other two rims choices I'm not sure what my options are.
I heard after a certain size tire the truck has to be regeared. I plan to do that at a later date...so for instance would 315/70/16's be heavier than 285/60/18's...Any light you can shed on this well help.
Our trucks come with high positive offset, so yes less positive is going to stick them out, but negative would make it stick out a lot. It will also do horrible things to the scrub radius. Not necessarily important if looks is the priority, and you like the look of wheels sticking out past the body.
As for re-gearing. The 285/60/18 would be fine on the stock gears, it is a 31" tire so smaller then the Pro4X factory wheel size. The 315/70/16 is an odd size but a 315/75/16 is a 35" and would really benefit from re-gearing. If going with a 315 you will want to go with a negative offset rim so that they rub less on the frame when turning.
As for re-gearing. The 285/60/18 would be fine on the stock gears, it is a 31" tire so smaller then the Pro4X factory wheel size. The 315/70/16 is an odd size but a 315/75/16 is a 35" and would really benefit from re-gearing. If going with a 315 you will want to go with a negative offset rim so that they rub less on the frame when turning.[/QUOTE]
Yeah sorry I meant 315/75/16. I do plan on regearing eventually but for a while I might have to run the stock gears and I don't want to mess up anything. I think I would be happy with 305/75/16's as well. I am still doing research but within the last day I have narrowed my rim search down to 16's with the level 8 strike 6 or level 8 tracker pros because they are pretty light at 21 and 22lbs.
I am pretty sure I want to go with All Terrains but what are people getting mileage wise our of M/T's?
1 - 3 of 3 Posts
