I'm looking to finally replace the crap stock tires on my truck. I have aftermarket 16" rims with a +10 offset and am looking to go from the stock 265/70 to a 265/75 tire. I know this is a stock size on the Pro-4x but that is with a +30 rim. Is anyone running a +10 rim with 265/75's? I'm just wondering if I'm going to have any rubbing with that combo.
When asking questions such as this you need to gave ALL available info as with offset one also MUST know the rim width to give the proper answer... But considering that you're only asking about a tire that in truth is but 1/2" taller into the fenderwell your answer is MOST likely no there will be no rubbing...
Your best bet is to have someone sit in the truck and slowly turn the steering wheel from full left to full right while you look for the areas that are tightest. Then assume with a 1" taller tire that those spots will be 1/2" tighter with the new tire size.
