What would be the largest tire/rim package I can get on a 2003 Frontier XE Crew Cab V6 model without a lift kit being installed? It has 265 70 15Rs on it now. And what lift kits are available for this aformentioned year and model?
THANKS!!!:)
Well I know you can't really go much bigger then maybe a 32", so whatever combination under a 32" tire would work. There is a 1st gen sticky. Also, lift options depend a little bit on 4wd or 2wd
Discussion Starter #3
Right now I am just researching possibilities with this vehicle as I bought it yesterday. I've got a reputable shop that does the work as they lifted another vehicle and installed tires/rims on it for me a couple of years ago. Its 2WD.
ok, well, with lifts, you can crank the torsion bars up front(there is a write up on how to do that) and the back you can add shackles/add a leaf's/etc.
