1 - 4 of 4 Posts
Hi all,
My tires are really rough and I know I need something different before the winter. I just don't think if I can afford new ones right now but I found a pretty nice set of used ones cheap so that would at least be better than my current ones for awhile and let me save up. The only thing is they are size 265/75r16 and my current tires are 265/70r16? Do you think those would work still?
Thanks-
If you have room for 1/2 an inch more tire when turning or have your suspension fully compressed they should fit fine. Your speedometer will be off just a bit and you will calculate it to have a lower MPG but it likely won't be that different. You will also find it accelerates just a bit slower off the line but I think if money is the issue and you think you have room you should consider them.
I'm sure they will work, those are close to specs. I went a touch bigger with no problems.
1 - 4 of 4 Posts
