1 - 4 of 4 Posts
For those of you that ride in the sand and climb dunes, what psi do y'all run your tires at? I've heard a few people say that if you lower the psi by about 10 then it softens the tires up a little bit causing better traction in the dunes. Thanks for response!
ya the lower the psi the better when im out in glamis or pismo i run 12psi in the front and 15 psi in the rear sometimes less. Ive gone down to 8 psi sometimes you just have to keep am eye on your tire bead make sure you dont pop off the wheel.
1 - 4 of 4 Posts
