Hey guys,
I'm getting ready to do the timing chain tsb on my truck, 07 nismo, 4x4, 120K. I going to go ahead and replace the fan clutch, idler pulley, and tensioner pulley bearing. What else should i consider doing while I've got the timing cover off?
Thanks in advance,
hoki
Water pump, serpentine belt and tensioner.
Hey guys,
Thanks in advance,
hoki
Can you please post a link to this TSB?
I would replace the primary chain and tensioner, as well. Also, the water pump and thermostat while you are there. I don't recommend using the sealant mentioned in the bulletin. A better choice is getting Permatex Ultra Grey Rigid High-Torque RTV sealant in a caulk tube to be used with a caulk gun. You are going to be laying down a lot of sealant and this is the best way to apply it. The sealant is pretty much the same as what Nissan recommends.
