Can’t Nissan build a decent chain adjuster??
I am very disappointed in Nissan. I purchased a 98 Frontier 4x2, 4 cyl brand new. I gave it the very best of care. After only 160K miles the lower timing chain adjuster failed. The adjuster is a curved aluminum part with a plastic piece, not even bonded to it that the chain rubs against. The plastic piece wore thru to the aluminum and caused the unit to fail. I had to tear the engine down removing oil pan, front covers etc. to get to the chain and adjuster. This repair will cost me hundreds of dollars and much of my limited time. The dealer wanted $1750 to repair this, and their mechanics have seen this a number of times before.
When I look at the adjuster that failed I think what a krappy built part that is. For such a critical part, couldn’t Nissan build something of quality? The plastic piece is only held to the aluminum by plastic tabs. The wear through point was on the top where the adjuster plunger pushes against it. Like there is too much pressure there?
I think the expectation for Japanese motors is that you should get at least 300K miles with any care at all. Maybe belts, alternators or such but not the main engine to fail. I might as well have bought a damn Ford.
Seems the company should at least offer a replacement part that is upgraded? I have to replace with the same poorly engineered part. I wanted to keep this truck till I die, but I guess I’ll have to sell it and find something else, as I’ll wonder when the adjuster will fail again. Has anyone else had this problem?
