1 - 10 of 10 Posts
This probably one stupid question but can you use a 3/8" brass hose fitting to connect the two coolant lines? I could not find a 3/8" fitting ANYWHERE! It should not be that hard to find a simple part...
I Used A Plastic Vacuum Line, Been On There Years
Sounds good! I wasn't sure if it'd get to hot for the plastic that's why!
Brass is just fine too. I think thats what I used.
Alright guys ill give it a try first thing in the morning!
i haven't done this yet to mine, can you actually feel a difference in the truck's performance or does the mpg get any better?
there is no major difference in power or MPGs but it did drop the temp of the throttle body down a good amount and thats always a good thing if your building power in other places.
i got my setup on ebay someone was selling as a kit. think it cost me $8 total. try ebay
Well Its Not Going To Help Mpg, The Idea Is To Create Denser(colder) Air Which The Ecu Will Add More Fuel To.
Discussion Starter · #10 ·
Well just finished doing this and i gotta say it was probably the easiest mod! It literally took like 7mins to do. Would have been faster but was taking pictures as i went.
1 - 10 of 10 Posts
