I'd like to know if anyone has replaced theirs.
Problem-MPG are still too low more than normal.
Check - Service manual says that if there is a big drop in MPG you should check the TPS position and the gap (see picture). I went to check it after the truck warmed up and it still was not warm enough for the plunger to push the gap closed. Adjusting my TPS is my goal but I cannot do this when the thermal plunger will not open all the way.
The plunger is located in the throttle body and senses coolant temp. When it gets hot the plunger moves forward and allows the truck to idle at a lower throttle.
My plan - I am going to breakdown and get a OBDII scanner so that I can easily measure coolant temp to make sure that the coolant temp is where it's suppose to be to open the plunger. If the plunger is malfunctioning I will have to replace it. Courtesy has the part for 120.00$ WOW! That's a lot of $$$. Maybe cheaper to find a whole new throttle body off ebay.
This is a picture of the space gap when the truck is cold. When the truck warms up the gap should close. Mine closed a little bit but not all the way
There are two marks on the fast idle cam (hard to see) the first mark is for cold and the second is for when the truck is warmed up and running correctly. The plunger is located in the throttle body and senses coolant temp.
