I'm pretty sure I have a leak here. Going to be taking the timing cover off this weekend so I want to reseal this.
Is there a gasket? If so which one? I'm finding gaskets described as thermostat housing to manifold with two bolt holes and square hole in the center as the coolant passage. Is this correct? Also, rtv or no rtv? Is the red high temp stuff good enough?
