Hello all,
I've noticed a couple things on my 05 Nissan Frontier Nismo this past winter. My truck would take a super long time to warm up and its seemed the heat wouldn't start working until the truck was moving more then 30mph. But once it was warmed up it stayed warm. I also noticed that my temperature gauge on my truck was always reading the same no matter what. Its always stuck in the middle and does not fluctuate whatsoever.
do you think I need to replace my Thermostat for this issue? Could it be the temperature sensor? I'm thinking about just replacing the Thermostat just because the part isn't that expensive, however, I wasn't sure if I should be getting the t-stat that opens at 170 or 180. Will this make a huge difference? The t-stat I'm looking at is Beck and Arnley which opens at 180 apparently.
Does anyone have any insight on my issue? Thanks in advance!
