261 - 273 of 273 Posts
I ended up getting the Thorley Short header with an ebay 4-cat package. That should set me up for the front part.
It looks like the Thorley Cat-back is not in stock right now, so I'll wait.
I need some quick help. Looking like I have a clogged cat on my 2015 and I'm not able to drive it any distance.
For me, this is an opportunity to get full engine-back exhaust without my wife complaining, too much.
For simplicity, I'm guessing the Thorley LTH, Mid-pipes, and cat back exhaust are all I need to do a complete bolt-on exhaust, correct?
Here's the thing, while I don't have emissions in FL, I would still like to have cats. They clean the air, they quiet the sound, and they won't throw a CEL.
What are my options? Is there a bolt-in Mid pipe with cat that would fit perfectly between the LTH and Cat-back? Or should I just get the full Thorley package and have a shop weld in new cats?
Thanks.
I had bad cats in my mid pipes, so I bought a pair of DT B pipes(different name for mid pipes but it's the same thing). Then I purchased 2 magnaflows cats from Amazon and had them welded in. Also pick up some reflex gaskets. I'll find the number for the cats if you want to take a look.
Magnaflow 94605 universal for $76 each on Amazon.
Thanks. For now, I decided I would keep the front part as close to the stock setup as possible, just better flowing. I bought the Thorley Short-Pipe Headers and an ebay Catalytic Converter set. I chose this set particularly because there was a lot of good feedback from other Frontier owners. Should be in this coming week.
Oh, do the Thorley headers come with front and rear gaskets or should I purchase a set?
317305
317306
You will have to purchase the gaskets separately.
What are your plans for the rest of the exhaust?
I didn't find anything available many of the websites, it's possible the coronavirus has made a shortage.
I'm going to keep the cat-back stock, for now, and be sure that this solved my issues, after all, my truck is down right now. Ultimately, I'm going to look into a Thorley cat-back or do a custom exhaust with a Flowmaster 40 series. Those are my top sounding exhausts. I'm also hoping that by retaining all 4 cats I can keep the exhaust tone as mild as possible.
Honestly, the only reason I went out and bought headers is I'll be damned if I'm going to go through that much work removing rusty bolts and B-pipes and not replace the rusty stock headers, as well.
Ninety-9, I'd recommend the FlowMaster 50 series if you're going the Flowmaster route. I have twin 40s on my Grand Prix and they're only 2 chamber, so they drone quite a bit.
317492
these would've been considered shorties on older trucks lol. There is a guy on here that has high flow primaries and secondaries..and I believe a custom exhaust. Is it Rodney? Is he still around? Also you might want to get vibrant resonators.
I'll check it out. How does the 40 and 50 series compare to the Thorley?
Also, this came in. Just waiting for the cats.
317574
317575
317576
