For those of you who wanted to know about a "Mini-Lift" from Prerunner Greg (same maker of the big brother titan leveling kits) I must say that all of the parts in the kit are crafted with care and all of the parts came packaged very well so as not to get damaged in transit. Both the front spacers and rear blocks are made of aluminum and precision cnc'd. This kit is so complete it even came with cotter pins. The instructions are very clear (the instructions did say they were for the titan but they worked step by step just fine for the frontier as well) and direct for the front however there is no insturctions for the rear. ( I dont imagine if you are going to try this at home then you would need instructions for the rear but for those that have not worked on cars before it might be useful.)
So what's in the box
1. A pair of front aluminum front spacers
2. A pair of rear aluminum blocks
3. A set of U-Bolts
4. A Pair of new Bump-stops
5. A the necessary hardware to put the kit in (except a 13/32 drill bit which is needed for the new bump-stops.)
6. Two new cotter pins
3. A set of U-Bolts
