1 - 3 of 3 Posts
Its finally time. Ive been having a oil on the sides and back (towards the tailgate) of my valve covers. When i changed my spark plugs i snugged up the bolts. Now its leaking worst and at times i can smell it inside my truck with the ac going. I picked up the gaskets this week and i need a guide on replacing em. I searched and couldnt find one. Please help if anyones done this. 05 Nissan Frontier Se CC SB 4.0.
Rogue Admin
2007 LE 4x4 Crew Cab Long Box
There isn't much to them - they use silicone in the corners where the seal turns up (you'll see when you get them off). I just replaced mine while I did the spark plugs, so I had the intake off. Not sure if you need to remove the intake to get the covers off, I would imagine it makes it easier to get in there to clean. I used silicone in the corners again to hold the new ones in place while installing
Thanks wasnt sure and wanted to make sure i wouldnt miss anything. Ive done a head gaskets on a Ford ranger but it had alot less stuff. I also try my best not to unplug the MAF or Throttle body its a pain to reset it and i still get a P0507 code periodically but it hasnt affectted my trucks performance.
1 - 3 of 3 Posts
