DISCLAIMER:
Neither I or Club Frontier.org can be held responsible for any actions taken when modifying your vehicle, should any harm be done to it from the information provided below it is your own fault. Bottom line is this, if you don’t feel comfortable doing ANY of the tasks outlined below, take your stuff to the pros. Some sections below will be purely from my experiences and others will be from online sources that I feel do an excellent job of explaining and see no reason to reinvent the wheel.
This thread will be a work in progress over the next few weeks. I'm still working on making it as functional as possible for everyone, beginners to experts. It is my hope that this will become a sticky for the audio guys similar to Jen's suspension sticky.
So you want better sound from your stereo. There any many options you can take to achieve this goal. What is considered good enough some may not be to others. This thread will help reach your goal from mild to wild. As a note, This guide is written in a manner resembling a flow chart, so it starts with the most basic stuff and gets more advanced from there.
This info is primarily for 2005-2012 Frontiers. Much of the info below is still helpful if your looking to upgrade but won't necessarily be specific to your 2013+.
_
The Factory Radio may be good enough for you already
Before you start just dropping money into speakers and such, you may be able to make the factory stereo sound decent enough to the point where you are happy with it just by adjusting some of the settings. Depending on what factory radio you have, the settings will vary. To my knowledge there are three different radios Nissan puts in these trucks: Basic, 6 disk Premium, and Rockford system.
What radio do I have?
The basic radio (XE/ SE without premium sound) will be the most limited only having adjustments for bass, treble, balance, and fader. The basic system also only has 4 speakers total (two 6x9’s in the front doors, and two 6.75” in the rear)
The 6 disk radio (SE premium/LE/NIS/PRO, KC only?) will be slightly more advanced than the basic having adjustments for bass, mid, treble, fader, balance, and speed sensitive volume. This system has 6 speakers total (the same four as the basic with the addition of two ¾” tweeters on the dash )
The Rockford Fosgate radio (LE/NIS/PRO, CC only) is by far the best factory system available in the truck having the same adjustments as the 6 disk but better internals with optional satellite radio and bluetooth. This system has 10 speakers, 2 subwoofers total, and has a factory amp putting out 380w(coax. 6x9’s in front doors, coax 6.75” in rear, two 2” mid tweeters on dash, two 3/4" tweeters in the rear doors, and two 6.5” subs under rear seat)
The best starting point is to just start playing with the settings on your radio until it sounds good to you. This will probably take about a week of listening to find the magic numbers. From my experience the stock rear door speakers are absolute crap, so try biasing the fader to the front more. My magic numbers with the factory 6 disk were: Bass=+3, Mid=+2, Treble=+4, Fader=F4, Bal=R1, SSV=mid.
If you are still unhappy with the sound it’s time to take more drastic measures and read on.
_
So you have come to the conclusion that your factory system is just not going to cut it…
Great Intro to Upgrading your System
You now need to ask yourself a few questions about your end goal before continuing:
1)Was the factory radio able to play music from all of the sources I wanted?
a.Yes, see option A
b. No, See option B
2)What is my budget? (CHEAP, low, mid, high)
3)How comfortable am I with wiring/ taking apart the inside of my truck?
Once you have these questions answered you can make your move:
I will say now that a great place to get you components is Sonic Electronix, I have been ordering from them for years now without a single issue. Fast shipping, LOW prices, and a wide selection.
Car Audio Stereo - Car Subwoofers - Car Amplifiers and Speakers
Option A:
On the CHEAP, if the factory radio plays all of the sources you want, start by upgrading your speakers. Start with the front doors as these will give you the most noticeable improvement. The rear speakers are absolute crap, so if you can replace them as well.($20-$1000 a pair) Please take a look at my basic speaker design discussion before choosing. Car Speakers | Component & Replacement Auto Speakers
Option B:
On the CHEAP, if the factory radio does not play all of sources you want, start by upgrading your radio or head unit. A basic unit with some inputs runs about $60-$80. Of course if your wanting all the bells and whistles they are by no means cheap and can be over $1k easily. Please refer to the head unit discussion. Car Stereo | Car CD Players | Head Units & In Dash Receivers
Option C:
For a low to medium budget build, it’s a very good starting point to upgrade both your speakers and head unit (this will be the point where MOST, non audiophile, people are satisfied) Usually you can find some radios that come with a pair of speakers or a la cart. ($$ Varies depending on what you choose) Please refer to the speaker and head unit discussion threads.
If you are satisfied with your setup now, congrats! If not, keep reading:sign7:
_
Alright, well you’re still not happy…
Before moving any further forward try fine tuning the radio again (stock or aftermarket). With new equipment comes the need to adjust settings again. To avoid distortion, try to only reduce values from the flat baseline. (Free)
Again we need to ask some questions to see what we need to fix:
1)Why are you unsatisfied?
a.Not enough bass? (Tune, Option D/E/F )
b.Too much highs/ mids / bass? (Tune)
c.Just not loud enough before distortion? (Option D/E/F)
d.Just doesn’t sound good (ALL)
Make your move:
The below options are more complex to install than anything mentioned prior, but can be learned with some patience and attention to detail. Both options include adding an amp(s) to your system. They can be added to a stock headunit or aftermarket, but I would recommend that before adding any amps to your system you first upgrade the stock headunit to one that has the correct preouts.
Option D:
Add a subwoofer, enclosure, and amplifier. This will really bring out the lows in your music and is typically needed to fully round out the sound in a truck. In our trucks an 8” sub will satisfy most just looking to improve the overall sound and add the needed lows in your system. If you’re looking to “BUMP” and be heard from a distance, an 8” probably won’t be enough for you. Many online stores sell packages with everything you need to add a subwoofer (speaker, enclosure, amp, associated wiring) or you can buy each component a la cart. Price will vary greatly depending on the quality, condition (used/ new), and how extreme you want to go. Again please review the Subwoofer and amplifier sections before adding anything.
(Sort Price: Lowest First) Amp + Sub Combos | Car Audio | Car Audio, Video & GPS at Sonic Electronix
Car Audio | Car Sound Systems at Sonic Electronix
Option E:
Add a full range amplifier to your already upgraded speakers. This will add headroom to your system which allows you to listen at a slightly higher volume with much less distortion than the same volume when powered just off of the deck. It can also help clean up the sound by giving your upgraded speakers the power they want to play more accurately. ($ varies, >$50) Take a look at the discussion on choosing an amplifier to match your system.
Option F:
Add an amplifier(s) that will power all of the full range speakers you want and a subwoofer(s). This of course will be on the more expensive side of things and can be done in a variety of ways. The main difference with this option is you can choose many different amplifier setups that will do pretty much the same thing. For example, if you want to amp 4 full range speakers and a subwoofer, you could do it by using either a 5 channel amp or a 4 channel amp and a mono amp. Refer to the amplifier section for more info. ($ varies depending on choice)
_
This is as far as I feel comfortable giving advice on as Option F is as far as I have personally gone with any system I have done work on. If you’re still unhappy with the sound after reaching Option F and you have properly adjusted all settings, you can still go further. At this stage in the game you should know enough to research your next step on your own. If you do go further please share your newly gained knowledge with me and this community
If you are looking to further your knowledge a good starting point where I learned a good amount of what I know from is Crutchfield Research: Learn about Car Stereos & Components
Some other articles to look at for more info:
- Better Car Audio — Three Degrees of Car A/V Happiness
- Car Audio Terms Glossary
_
_
a.Yes, see option A
b. No, See option B
Option A:
Option B:
Option C:
_
Make your move:
Option D:
Option E:
Option F:
_
