Hello everybody, I have almost 8 months with my truck (`02 2.4L auto KC) and since I bought it I noticed that the indicator in the temp gauge jumps to half way (between C and H) when the ignition keys is turn to ON (before starting the engine), and stays there forever, even when the engine is on and cold and warm.
So I thought it was normal since I haven't had any overheating problem, until this week, the water pump fail, drop the coolant liquid and I didn`t noticed the radiator was empty so drove the truck about 15 minutes before I notice it was overheating, I sense it because I felt hard shifting, driven and heat smell, so I pull over and the engine was over heated.
The indicator on the temp gauge never show any kind life.
I replaced the water pump, the thermostat and the coolant fluid and the temp gauge act the same as the very first day I bought the truck.
So, you guys ahve any advice, on what would be wrong?
TIA
Rgds
TIA
Rgds
