1 - 2 of 2 Posts
I am getting an A-frame pop up camper with electric brakes, single axle. Looking for thoughts/recommendations between the Tekonsha Prodigy P3 and Tekonsha Prodigy P2. Brake controllers. I know they both get good reviews, but wonder which works best with the Frontier? Specifically which is easier to mount, and easiest to use. I won't be towing multiple trailers or switching it back and forth between different vehicles.
I have the P2 in mine and even that's a bit overkill P3 is pretty much same both do up to 4axle,preset braking boost levels,self leveling,proportional just more presets so if your towing different setups. The P2 has been a good controller for me never had a problem with it through different vehicles. Even has a pocket sleeve mount for it to slip into instead of permanently mounting unit then stick it in your glove box when your not using it
1 - 2 of 2 Posts
