TCM programming and update repository
19K views 26 replies 8 participants last post by  Frontinator
Had my 2021 updated for the original shift shock tsb NOT yet for the pawl recalls.
  • Year: 2021
  • 4WD or 2WD: 4WD
  • Truck build date: 3/21
  • Issues noted prior to flash/update (shift behavior, noises, etc) - No real issues just wanted the latest flash at the time.
  • TCM version prior to update: 9BT6A
  • Date of TCM update: 3/22
  • TCM version after update: 9BT6D
  • Post update observations - anything "fixed"?: The shifting was smoother post flash and remains great today.
This was the tsb
Had my 2021 updated for the 2 different pawl recalls. they did both the pin and the software.
  • Year: 2021
  • 4WD or 2WD: 4WD
  • Issues noted prior to flash/update (shift behavior, noises, etc) - No issues
  • TCM version prior to update: 9BT6D
  • Date of TCM update: 12/23/2022
  • TCM version after update: 9BT8B
  • Post update observations - anything "fixed"?: no change - was good before its still good
What locations on the Web do you know about TSB's?
Thank you
and/or go here and search by vehicle. look for the manufacturer communications.
