Interesting.
Are you eventually going to go with a UCA or stay with your current setup?
Actually I plan on getting control arms probably at the end of this month. I didn't have the money last year to get UCA's and coilvers all at once. When I do get UCA's I will send my coilovers back to ICON to have the internal droop stop removed. I think they said it was $35. to that.
Some of us (or maybe just me) think that you should run the aftermarket UCA's with the coilovers to avoid contact, guess not.
I just copied my post from anther thread.
No control arm eliminates coil bucket contact, they just reduce it. The advantage to using after-market control arms and extended travel coilover is the additional down travel. About an 1" to 1 1/2 more drop then a coilover set for stock UCA's. So you will have contact but you are adding more performance.
Coil bucket contact with UCA's with coilovers is different then with a spacer lift. With A spacer lift you actually loose some down travel and the contact happens sooner, like then you go over a speed bump.
