1 - 18 of 18 Posts
Does anyone make a replacement for the interior of the tailgate that would be flat and smooth so it is not a torture rack to craw up onto? Something rugged that would stand up?
How about cutting a sheet of plywood to fit and using the current cover to drill holes in proper locations and then install that over the current one?
I was hoping to find one more robust and weather resistance out of hard plastic or something similar to the material a cutting board is made from...
Sent from my Nexus 6P using Tapatalk
I would also be interested in something like this. I have thought about cutting a piece of rubber bed mat material to fit the tailgate and securing it someway.
Do you have the factory spray in bedliner or no?
Not knowing your height, I always step up on the left side. Tailgate down, Left foot on the edge of the bumper, grab the inner lip on the bed side with my right arm and hoist myself up and swing right leg on to tailgate. I'm 5'8" and It's a slight feat of flexibility, but always manageable.
Use the same method as the plywood but get yourself a sheet of aluminum or better yet a sheet of titanium.
I believe they sell thicker sheet metal formed for this for the tacoma. (Meant to stiffen the tailgate) you might see if it'll fit and if so, if you can buy one either undrilled, or drilled to match the frontier.
Aluminum is great except if uncoated it oxidizes and every time you tough it with make your hands and clothes black.
2022 4X4 CC SV
Here's what I did. Bought a 4 x 8 piece of lauan and cut to fit. Bought indoor/outdoor carpet from Menards.
Stapled carpet to lauan and secured to tailgate with 6 small lag screws.
Discussion Starter · #12 ·
Yes i do... or as we call it hell on knees...
Wonder if you could get a remnant piece of synthetic countertop cut to fit. Corian or whatever. The material should hold up to the weather, although might be too thick/heavy with the weight limits on the tailgates.
Or something like this:
https://www.onlinemetals.com/merchant.cfm?id=1526&step=2&top_cat=181
That is not a bad idea at all, except if it were me I would spend the extra money and go with the Kydex. better strength to weight ratio and moldable if wanted.
1 - 18 of 18 Posts
