1 - 12 of 12 Posts
ok so I want to adjust my tbar to level my truck, cause the rear is higher then the front. I read the write up on tbar crank, but I want to make sure im doing it right.
First I lift front end and lubricate nuts
Second I loosen the adjuster bolt to where I want my height to be.
third I tight the bottom nut and ride a bit till it settles in?
does it only lift the front? or whole vehicle?What would be a safe increase in height?
Thanks in advance
You tighten the nuts to achieve lift and it only lifts the front. Once you climb under there and look you will see how they work. Really simple concept.
When you lift the front end there is not too much you have to worry about but this is going to mess up the alignment a bit.
An inch "could" still mess up the alignment, u can drive it still but how much do u like ur tires!
I think alignments are like $60
1 - 12 of 12 Posts
