Ok, I have a 2.5 inch coil spacer, after an alignment I feel a small vibraton in the steering wheel but only at speeds of 75 and up. Did I need to keep the sway bar disconnected after the lift install? If I were to disconect the sway bar how would it effect the ride quality.
My driving habbits are mainly interstate with the occasional lite trail/beech visit.
A sway bar on or off can not cause a vibration.
whens the last time you had your tires balanced
you cound have thrown a weight
How was your alignment. I just had a 2.5 kit put into my truck and the installer said he needed every part of he camber bolts that he installed. the alignment was way off
Thanks guys. After firestone did the alignment everything was in range. I get new tires in a week, if it's still bad after a mount a balance I'll take it to a different firesone, mine is worthless!
