The quick answer is no and for the position of the swaybar on the 05+ Frontiers, its kinda hard to make a disconnect work since the suspension is pretty tight and it would probably hit the swaybar anywhere you try to rotate it.
^+1
Disconnect an end link; then flex the front with a jack.. lotta crap under there tie rod, LCA, Shock/Mount, Schrader valve on the C/O etc...
600s were too stiff for my set-up, 500s are perfect w/sway bar.
