1 - 3 of 3 Posts
For reasons I won’t get into here, I am going to swap my lift spacers on the front of my truck. Same lift height (2”) and alignment was done after the current ones put in. I won’t be taking apart any adjustable things (only the upper ball joint, sway bar end links and 3 nuts that hold strut top in), so alignment shouldn’t move. I shouldn’t need to redo the alignment, right? Shop that did it said only the toe in was slightly out (expected) after I installed the current spacers.
Thanks.
1 - 3 of 3 Posts
