1 - 9 of 9 Posts
So I Have Done "ALOT" of searching for lifts for my truck, my options are "VERY" limited..
They Offer:
-FabTech-
6" Suspension Lift For Aprx $18oo.oo ($21oo.oo If You Purchase The Leafs For It)
-Ready Lift-
2.5" Lift In The Front, And 1.5" Lift In The Rear For Aprx $368.oo
They Do Have Several Other Leveling Kits, Daystar, Revtek, Procomp However Has A 5" Lift For About The Same Price As The 6" FabTech
So I Guess My Options Pretty Much Are 6" Or Simply Level..
I Was Thinking If I Put A Ready Lift On (Raising Front 2.5"/ Rear1.5) Then Threw 285/75r/16 Mud Tires The Hieght Of The Tires Would Help As Well Possibly Lifting The Front Up To 3.5" And Back 2.5"
What Do You Guys Think?
Urban
Discussion Starter #3
Yeah I Considered That As Well, But If You Lift The Body How Do You Cover The Space Between The Bumper In The Back.. I Dont Want That Gap..
Have you looked at the 5" Calmini lift?
Discussion Starter #5
Im Sure I Have Ran Across It Thru-Out Searching I Will Look It Up Again..
With A 5" Lift Tho, Dont I Need 5" Back Spacing For My Tires? And With That Big Of Tires Will I Need To Shave My Fendors Down?
Only the FabTech requires you to use a different rim size.
Discussion Starter #7
Hmmm I Did Not Know That.. Why Is That? So I Could Get A Calmini And Still Use My 16 Rims Just Sling More Rubber And Get Some 33" Tires..
The tie rod is flipped on the steering knuckle changing the clearance from the suspension to the wheel.
Discussion Starter #9 (Edited)
ahhhh okay that makes since now.. i didn not know that i appreciate the info.. defininatly give me more to think about now..
what are "Sway-a-way Coil Overs For?
1 - 9 of 9 Posts
