1 - 4 of 4 Posts
Just installed my new Clarion head unit, everything works, but when I started the truck, the Supplemental Airbag light is flashing. I didnt really mess with any of the wiring harnesses minus the radio. I did route the Sirius radio antenna between the headliner and the weather seal, and when i got to the back passenger corner, I had to take the rear seat belt off to remove the corner panel. Could this cause the light? The manual says its an airbag/restraint light. I made sure the bolt was back tight and removed the neg cable from the battery for about 5 min, no help.
Hmmm. So i just read the SM, says to remove both battery terminals before removing the tensioner. So, ill remove both cables now and see if it clears. Any other ideas?
1 - 4 of 4 Posts
