1 - 4 of 4 Posts
2012 Nissan Frontier Pro-4x 6sp King Cab
I just recently purchased a JBL Stage 800ba powered sub. It has a pretty small amp so it doesn't really need direct power from the battery. Does anyone know of any existing power sources i could tap into? I have a 6sp which makes it difficult to enter the firewall without cutting up the existing grommet or drilling another hole. Any insight would be greatly appreciated. :)
Personally, if it's aftermarket I would always run an amplifier 12+ directly to the battery.
That said, JBL Stage 800a uses a 10-amp fuse, meaning it won't draw more than 10-amps. You could try tapping into the fuse box over on the passenger side, behind the glove box. The 6th fuse up from (starting from the bottom) on the RIGHT side should have a 15-amp fuse in it - this is for the factory subwoofer. On the fuse box cover it is labelled "WOOFER."
I ended up writing up a small guide here:
Thanks so much!
1 - 4 of 4 Posts
