1 - 3 of 3 Posts
i need suggestions here. I have an 01' Fronty S/C. The other day i was backing out of my spot and CLUNK my outer tie rod stripped my center link. so i got a new complete kit with inner/outer tie rods and center link. Figured if im doin it should all be new. the outer TR came out with a little hammer tap. I then unscrewed the center link from inner TR. I got the top nut off with sum serious WD and pipe help. I then smacked the TR with a hammer and nothing. soaked it in WD, still wont budge. Any suggestions what to do?? Also i did this with the wheel on and no jack. Do i need to relieve tension maybe first? Any help would be great, i already missed 2 days of work! thanks all
Its probably going to take some heat to break it loose. I bought one of those hand butane torches and it helped me to break some stuck bolts. You could also try something more specialized thatn w40... like liquid wrench, or pblaster
Discussion Starter #3
ok i finally got it after 2 days of soaking it and beating it with a hammer. now im looking forward to a fun day of doing a tune-up. yay
1 - 3 of 3 Posts
