Recently put a leveling kit on my 05. Took it in for an alignment today and the shop couldn't get the cam bolts loose. It's an 05 so it came from the factory with them. The tech said the bolts are seized in the bushings. Couldn't apply heat because it would melt the bushings. So I had to settle for them just adjusting the toe.
What can I do to get the camber corrected. It's 2 degrees out right now and I don't want it to tear up my tires.
