1 - 8 of 8 Posts
So I thought I would mod my stock air box, I'm not sure it will help with performance or MPG but I knew it could not hurt either, I dont offroad this rig so water crossing is not a concren, Im just hoping for a little more MPG :laugh: if possible.
I had some old intake parts from my current stable (Mazda 6, Honda Van) I found a 90 elbow that would work for this mod (idea from Volant)
1. cut hole in stock air bx (bottom Left) inserted elbow
2. Cut 2 3/4 hole in plastic filler (left of the Radiator)
3. Used siliconized air ducting to connect the two
Stock air Bx
New elbow installed
Hose connected to elbow then to opening next to Rad
Hard to see this but, this is the view from the front.
I will not see any gains from this till I get a K&N or other free flowing air fliter are my thougts.
Oh vegas ok it dosent rain much there.... cool mod.
In your picture #2 I see you still have the extended intake tube in the box. You need to cut it flush to the inside wall of the stock intake.
Discussion Starter #4
Wirenut! Thanks for the tip, are you running a K&N fliter?
Ya I'm running a K&N and also have the Gibson Catback with a 2 degree advance on timing
Discussion Starter #8
update on this mod??? well it has improved my MPG from 17.5 to 18.5 in mixed city driving the real gains are at hwy speeds..
1 - 8 of 8 Posts
