hey all,
just ordered a Stillen Rear differential cover for my '10 and was wondering , for those who have it, does it come with a gasket or can you recommend the best gasket to use for my Dana 44 rear?
thanks
If you're good with silicone.. no problem.
But, the gasket to have/use is the Mag-Hytec(I use one).
Just an FYI, you have a hybrid Dana 44 which is labeled an m226. This means most things for a Dana 44 like gears and lockers and etc... won't fit without custom modifications that nobody had really done.
I personally wouldn't reccomend standard silicone. No matter how long you let it set up, It will leak, trust me. Been there, done that. Make sure you get a non acid cure type, or ask the dealer what they use.
