Thanks, I should be getting my new HU tomorrow and this will help me out. I already got the speakers in with no problems. I'm thinking I may wire it up for an amp while I'm at it so I don't have to remove it again later when I decide to add a sub...chicknde said:To remove the headunit, start pulling where the two oulets are the bottom right corner. The panel will pop out and there are 4 or 6 screws holding in the headunit. All the door panels are the same start by taking off the small silver piece next to the door handle then take out the piece that is behind the door handle. If you use a small flat screw driver you'll be ok. This will expose one of three screws you will have to remove. The other two are behind the arm rest. To remove the arm rest simply pull it up. Its on there pretty tight but trust me pull up. Then you'll see the two remaining screws. Remove the three screws and pop the panel off. If you have power windows you will have to disconnect the harness to completely remove the panel. If you don't have power windows I am not sure how you would take the handle off. there may be a clip behind it. Hope this helps![]()
Where'd you get your RF 6x9's? I've been looking on crutchfield and they only have 2 - 6x9's that they say will fit the front door?Jboat said:Well I got it all done. It sounds really good. I got the RF punch 4 way 6x9's in the front doors, Infinity reference 6.5's in the rear, A/D/S tweets in the dash, and I built a box that fits under the rear passenger seat with a 10" sub. I had to remove the storage tray that was under the seat. I am running the RF sub with an old school 275 watt MTX Thunder amp. It's just enough bass to satisfy my needs... 8) The Crutchfield harness and adapter sure made things alot easier...
That's what I'm planning to do next...but so far I can tell you:gsattiewhite said:Can someone give advce on how to remove the rear door panels? I seem to be having trouble with the seat belt system on the door. Any help would be appreciated. Thanks
How did you get to the tweets in the dash?Jboat said:Well I got it all done... tweets in the dash...
