Hi all - I have 2 questions..
1. I brilliantly broke one of the step rails (nerf bars) off my '05. I backed over a rock in the southern Utah desert which decided to stand up on end. Cool way to be on 3 tires. Anyway, the 6 bolts or studs which come directly out of the body to hold the suckers on are un-brilliantly engineered to be as difficult as possible to replace when you shear off 4 of them. Are there any that actually bolt into the frame that I could replace this with?
2. I need to pull a trailer. Standard 4-pin hook up on trailer end. All I can find on the truck are these two plugs. Is this a Nissan thing which I can get an adapter for, are they (or at least one of them) actually for trailer lights, or do I need to go have something installed? I tried to find an adapter but nothing seems to be this actual shape.
Thanks!
Sandy
Thanks!
Sandy
