I'm making plans to replace my heater core next weekend and am currently reviewing steps in the Haynes manual. One of the steps is to lower the steering column, which refers to Chapter 10 Section 12. This section is for removal of the column. The general steps are remove steering wheel, remove knee boster and column covers, disconnect electrical harnesses, detach shift interlock cable, disconnect steering shaft from intermediate shaft, and then unbolting/ lowering/ removing the column.
My question is for the purpose of lowering the column for eventual heater core replacement, do I have to remove the steering wheel and disconnect the steering shaft from the intermediate shaft, or can I just disconnect the electrical harnesses, disconnect the shift interlock cable, and the unbolt and lower the column with steering wheel and shafts still connected?
ETA: Re-reading (actually looking at photos) it says you must remove the steering column (only in a photo caption and not in the instructional text). So, I guess my question is now can I remove the column and wheel as an assembly? It's strange the way they have the instructions - it says lower the column, then remove the entire instrument panel, then in the photos for removing the heating ducts the caption says remove the column. Why not remove the column in the previous step I wonder?
I have a 2008 Nissan Frontier LE.
