Heres my problem:
My truck is swaying from side to side and almost scarey when driveing in ruts on pavement. I have installed a new (upgraded/heavy duty) center link, had a wheel alingment, all balljoints, tie rods, idler arm bushings are in good condition (no play according to the garage) When driving my truck my stearing needs to be constatly adjusted with the wheel when I am trying to go straight. I do have big tires (33x12.50) and I realize that this will cause some sway/pull when in ruts but it is really excessive and my truck was not like this in the beginning when I installed the tires and the truck was stock.
*stearing needs to be constantly adjusted even on flat pavement with no rutts but not as bad*
My question is should I try and adjust my stearing box/worm gear? If so how do I do it and can it be reversed if this is not the problem?
When I purchased the upgraded center link I thought it would fix my sway problem but I think it has made it worse. Is there something that I shouls be looking for before I adjust my stearing box?:comphead:
Any coments will be very much appreciated.
Someone Plese help!!!!!!!!!!!!
Thanks
Grant
Thanks
Grant
