I'm looking for some help in diagnosing my 2007 SE CC 4x4 6spd manual that won't start.
I had recently gone to help a friend with his 2006 Xterra. Long story short, we pulled my batter from my truck and put it in his to pull some codes, etc. After that, I put the battery back in my truck and it wouldn't start! No crank at all, none of the usual ticking to indicate a dead battery. Interior lights and windows worked, dash worked, headlights, etc. When I did turn the key, the fan and radio would cut out as is typically when it's cranking.
I've checked the clutch pedal to ensure the pins on the switch are being depressed. Held it down and turned the key: nothing. I had left my multimeter at home so don't have an exact number but the voltage gauge was showing just under the '-' on the battery icon which is about 12ish volts. I put the battery on a trickle charger for about 10 minutes but still no crank. Fortunately I was parked on a slope so I shifted to Reverse, rolled backwards, and bump started it. Ok, it seems to be running fine so I drove it home, about a 20 minute highway drive.
During the drive, my speedometer isn't working. The tach and the rest of the gauges are fine and the voltage is indicating nominal. Also the SLIP, BRAKE, ABS, and 4WD lights are now all on. The TPMS light is also on but that had been on previously. I've attached a picture. The diagram that usually shows the 2 vs 4 wheel engagement is completely blank. Besides these visual cues, it ran like normal.
I got home and again parked on a slope just in case. I should have checked the voltage while running but I stopped it first. The voltage on the battery was 12.4V when not running. Seems ok there.
I swapped the starter relay (top left one on the white tray, correct?) around with others on the IPDM hoping to indicate a bad relay but still no crank. I haven't swapped in a brand new relay yet.
My Bluetooth OBD2 adapter spit out P0500: Vehicle speed sensor failure. Ok, that correlates with the speedo showing no output. Reading some threads shows that's typically due to a damaged wire. I have a 2" lift installed but it's been in for quite a while and I made sure even at full droop the wires and brake lines weren't being stressed. It still is worth checking.
Would the VSS have anything to do with the no start/no crank issue? What am I missing here? There had been no problems leading up to this and the only thing that happened in between was pulling the battery for about an hour, using it to help power the Xterra, and then reinstalling it.
Any help is appreciated and I tried to give as much detail as possible. I'm looking for ideas to continue diagnosing it after work tonight.
