21 - 32 of 32 Posts
Discussion Starter · #21 ·
Ground is good, checked with meter one end on battery post, other end on engine block.. I've got low voltage at the starter, thought I had previously checked that. Positive cable at the solenoid is low. So I have good volts at the battery and poor volts at the solenoid. There is a small fuse block just beyond the battery terminal on the positive cable , good voltage there.
Your not checking voltage, you need to set your meter on OHM's to check resistance inside your cables. The closer to zero the number the less the resistance. This allows you to not have to disconnect everything to check it.
There's like 5 or 6 fusible links in the fuse block located directly behind the positive battery terminal. Check ALL the fusible links to make sure none are bad. Two are on top & the rest are "hidden" on the side. Check the cable between the fusible link and the starter. You should be getting battery voltage. Follow Bajasam's recommendation, (post #22).
Reactions: raymond~
Discussion Starter · #24 ·
They are 6 fuses in that block, all are intact. They are 6 wires that disappear into the hard plastic sheathing that contains the wires. Clueless as to which goes to the starter, the sheathing branches off a couple of times between battery and starter. I'm trying to avoid cutting up the plastic sheathing to trace but may not have a choice. This morning I had just under 12v at the starter, tried to start and voltage dropped to maybe 3 v.
I know it was posted about already, but I never saw a response to it. Have you ruled out the ignition switch module yet? If you just get one click every time, couldn't that still be it?
Ive also had the "one click" symptom from aged terminals, and once I replaced them it fired up. I'd maybe peel and inspect the wire behind your terminal connectors for corrosion also.
I'm following along, maybe I'll learn something from this.
Best of luck
Discussion Starter · #26 ·
Not sure about the ignition switch, kind of saving that for last. The positive terminal is almost new and looks it, the negative is older but is in great shape. The ends of the couple of wires I can see at the fuse block at the battery has no corrosion at all. I may try running a heavy gauge wire straight from the battery to the solenoid. I know I'm not good on electrical stuff, but I'm about ready to concede defeat on this one. If I can't find the problem tomorrow, it's going to the garage.
21 - 32 of 32 Posts
