1 - 4 of 4 Posts
I've been looking for hours now between google and the FSM I downloaded trying to find a good diagram of the relays in the truck. I put a new starter on my truck a few days ago, and now it's doing the same thing it was before. Full power from the battery, but only a click when I turn the key. So before I go through the trouble of taking the starter back off to have it tested I'd like to check the relay. Any help would be greatly appreciated. Thanks
Cam
Cam
can you follow the wire up thru to the relay?
If the relay is in the IPDM, probably not. Honestly I haven't tried so I can't surely say no, but I'm assuming since there are just harnesses going into the module it'd be kinda hard to follow it that way
true that, i wasnt sure if it was just a plain ol big wire like on older rigs
1 - 4 of 4 Posts
