1 - 2 of 2 Posts
My front strut is squeaky other side ok to eliminate the squeak I spray the strut with wd40 towards the top of the strut and rubber top plate had them out several times they are tight and assembled correctly.
Using lovell struts and springs I think it is a problem with the rubber towards top plate may be slipping hit a good bump in road noise sometimes goes away.
thanks
I've used Seafoam Deep Creep to get rid of an annoying squeaking noise in my front end. It cleans and lubes. I had tried other lubricants but it kept coming back. You probably have dirt in there that when it dries it squeaks again.
1 - 2 of 2 Posts
