For a little while now, I've had a squeaking sound on my truck. It happens when going almost any speed, and does NOT occur when actually hitting the brakes, in fact it goes away when I do hit the brakes, and comes back when I release them (this is all while the truck is moving forward at most any speed). The funny thing also, is that it will change pitch/be present on and off when I am cornering; I tested this while I was on the highway with my drivers window down and swerving left and right very slightly. It also does not go away after driving for a little while, comes on randomly, etc so I can't pin it to any specific conditions.
A couple weeks back I put the summer tires/wheels on, which could (but most likely is not) the problem if one of my wheels lugnut(s) is loose and the disk brake is hitting the brake pads intermittently while cornering because of the looseness. I need to check the lugnuts tonight, although I don't expect any problems. I also just recently removed ALL the brake pads and put some 'brake disk quiet' goop on the backside to solve what I thought was the problem, which it isn't unless I didn't do it correctly/apply enough.
What do you guys think? It wouldn't be wheel bearings I would assume because that would produce a bad rumbling sound and would grow in volume the faster I went.
